2002 Pontiac Trans Am freezing up
dannyual767 on Wed July 18, 2012 4:32 PM User is offlineView users profile
Year: 2002
Make: Pontiac
Model: Trans Am WS6
Engine Size: 346
It's been a while since I've been on this forum but I'm back because two of my vehicles are having some problems. It's time for me to dust off my manifold and gauges!
My 2002 Trans Am cools just fine around town but on long drives, it'll freeze up. I'm pretty sure that the low pressure switch is bad or needs to be adjusted (if able.) Does this sound right? I'm about to take it on a trip soon and I know the ac will freeze up and blow warm air after an hour or so on the interstate so I'd like to fix it soon. Thanks for any help you can give me.
GM Tech on Wed July 18, 2012 5:04 PM User is offline
Good luck trying to find your low pressure switch-- you have none-- you have a V-7 compressor with a control valve that controls evap freeze-up and destrokes the compressor- One other reason for evap freezing is air in the system- has anyone ever discharged and recharged your system without pulling a vacuum first?
dannyual767 on Wed July 18, 2012 6:28 PM User is offlineView users profile
I've owned the car since brand new and the system has never been opened up. It cools great but the freezing up makes longer trips miserable.
Are there any other things that I can check to cure this freezing up problem or am I looking at a compressor replacement ?
Edited: Wed July 18, 2012 at 6:31 PM by dannyual767
GM Tech on Wed July 18, 2012 8:18 PM User is offline
control valve replacement-- or just turn off a/c for 2 minutes every half an hour on a trip
mk378 on Wed July 18, 2012 8:53 PM User is offline
Hook up gauges, set interior fan on low, rev the engine, watch the low side should not go below about 20 psi. If it does the control valve is not working.
dannyual767 on Wed July 18, 2012 9:55 PM User is offlineView users profile
Okay, now I understand. The "control valve" is suspect. I know that I need to put my gauges on it and I will before I replace any parts. I'm probably going to have to do what GM suggests for my next long drive since I don't think that I'm going to have time to do any underhood work due to career work. Two minutes off every half hour won't be too bad.
Where is the control valve located?
