Year: 1983
Make: Chrysler
Model: Cordoba
Engine Size: 318
Refrigerant Type: R143A
Ambient Temp: 70 F
Pressure Low: 15
Pressure High: 225
Hi Folks! My 1983 Chrysler Cordoba was "Professionally " converted to R134A, by the previous owner. At 70 F ambient, I get the following
When the readings reach Low side 15 PSI High 225 the compressor clutch cycles OFF
and stays OFF till the Low hits 40PSI and HIGH drops to 110 PSI, Cycles ON. AIR DISCHARGE 42 F during this operation.
Bypassing the LOW PSI Cutout switch. makes NO DIFFERENCE.
Buy passing the Clutch cycle switch (the switch w/ the capillary tube) causes the compressor to run constantly, LOW 10 PSI HIGH 200 PSI
with 35 F air coming out of the AC Duct.
I installed a new Clutch Cycling Switch, with new HEAT SINK GREASE, no change.
I KNOW I have a leaking AC hose.
Am I low on R134A? What say youse? Thanks!!
God Bless America!
Your system seems to be operating properly. The switch prevents the evaporator from getting too cold. Air at about 40 F means the evaporator itself is near 32 F. Should it get below 32, the evaporator will ice up and the system can't work. You can't get 35 F air in normal climates without icing problems.
If the 42F air is not keeping the car cool enough, there could be a problem with the interior fan or ductwork restricting the airflow. Leaves and mouse nests are commonly found in the fan area, the debris will clog up the evaporator.
Edited: Fri June 29, 2012 at 7:16 AM by mk378
No other car I can recall working on or owning, had the clutch cycle, that much. (Unless obviously low on charge).
Though I have limited AC service experience, I often get 35 F output temp, inside the car, with out freezing.
I am not yet, convinced, my Cordoba is performing normally. What about the LOW side PSI dropping to 15 PSI?
I am not trying to argue, I just don't understand and would like a little more "KOOL"!
THANK YOU!
God Bless America!
Edited: Fri June 29, 2012 at 11:56 AM by mikeceli
Any other input? 107 hits and 1 comment.
God Bless America!
Charge is probably a little low, but it's kind of hard to check at 70F ambient.
You should also check the evaporator for airflow restriction, which can cause cycling due to lack of heat load on the system. After nearly 30 years, especially if this was a smoking vehicle, the evaporator probably has lots of gunk on it. A good bath certainly can't hurt, and air will probably be fresher.
Joe
