Need TSB
iceman2555 on Fri May 18, 2012 9:18 PM User is offlineView users profile
I am searching for a GM service/TSB concerning the correct procedure for adding lubricant to the 'V' series compressors. I seem to remember reading this....well...it has been a while. GM got any leads?
GM Tech on Sat May 19, 2012 5:38 AM User is offline
V-5 compressors, when off the car and being installed as service compressor get the entire oil charge in the crankcase- by removing the oil drain bolt on its belly- When on the car, the compressor usually has 3 ounces in the crankcase at any given time- and oil added can be through the suction port
iceman2555 on Sat May 19, 2012 10:53 PM User is offlineView users profile
I know the procedure, I am seeking the tech/service bulletin that GM published when this compressor was introduced.
