2007 Chevy Aveo not cooling
BGerrin on Tue April 24, 2012 9:08 PM User is offline
Year: 2007
Make: Chevy
Model: Aveo
Engine Size: 1.6L
Ambient Temp: 80
Pressure Low: 75
Pressure High: 150
I've checked the system for leaks, flushed the system and pulled a vacuum, installed 24oz of 134a, the condenser is clean of debris, I've replaced the cabin air filter, the compressor clutch is running but I'm only getting about 60 to 65 degrees at the vent. Is there anything else I can try? Thanks
TRB on Tue April 24, 2012 10:19 PM User is offlineView users profile
I show the system calls for 21.5 ounces. Are your fans working correctly? Last thing swap out the control valve in the compressor.
