delphy v5
chippy on Thu January 05, 2012 4:36 AM User is offline
Year: 2001
Make: daewoo
Model: nubira
Engine Size: 2.0L
Refrigerant Type: 134A
Ambient Temp: 34 Cel
Pressure Low: 0
Pressure High: 0
Country of Origin: Australia
Hi there, great forum in the process of putting in a new motor, and just before the motor died the A/C did as well had it checked they told me it was the compressor. Long story short is i want to rebuild thre compressor and looking for parts for it.I have found oAnyway thanks in advance to who ever chimes in .
the wife said i want air con
GM Tech on Thu January 05, 2012 10:31 AM User is offline
Almost all V-5 system failures I see are due to loss of refrigerant- then someone sees it is not cooling or pumping well and says--"it's the compressor" So- how much refrigeant was in the system when a/c performance went south? If that is unknown- then your compressor is probably okay- may need a shaft seal if built before Sept 2002.
NickD on Thu January 05, 2012 4:24 PM User is offline
Got a Norelco electric razor for 31 bucks last year, replacement blades are 30 bucks, but see where the price of that same shaver is now 35 bucks.
Compressors are even worse than shavers, if you can find all the parts you need, far more expensive than getting a remanufactured one with the latter having a warranty. Perfect example is just buying a clutch kit, for a few bucks more can get the compressor with it, with that same kit installed.
That is if the compressor is indeed your problem, noted for excessive clutch gap for one, or just the seal. Know a guy regardless of the fault, even a flat tire, always says its the computer.
