A/C clutch adjust
padgett on Sun October 02, 2011 12:31 PM User is offline
Year: 1988
Make: Buick
Model: Reatta
Engine Size: 3800
Refrigerant Type: r134a
OK a/c compressor replaced a couple of months ago. Blowing 38F at ducts (working fine) when strange noise heard. Turned out that the pully ring had seperated from the clutch center.
Had another similar unit so removed pulley and top plate from that one.
Pulley went on fine and true (snap ring in place) but cannot adjust gap - pulls down to about .125" and that is it
Does anyone know what is going on and how to fix ? This just does not make sense. Yes, the key is lined up properly. Unfortunatly the only manual I have is for Delco HR6s and this is "something else".
Also have never seen this happen before, has anyone ?
Many Carpets
TRB on Sun October 02, 2011 3:35 PM User is offlineView users profile
Are you using the same hub. If not is the shaft of the hub the same length as the other one?
padgett on Sun October 02, 2011 3:54 PM User is offline
Both hubs (new and original) act the same. Saw a reference to spacers but there are none, just a felt pad. Feels like it is hitting a stop except there is not one.
Many Carpets
TRB on Sun October 02, 2011 4:29 PM User is offlineView users profile
Looking at the diagram I have, there are no shims. So I would think you have an incorrect pulley or hub. That's just a quick observation on my part. Something is causing it to not pull in enough or it's bottoming out before reaching the pulley face.
mk378 on Sun October 02, 2011 4:57 PM User is offline
You are using the special installer tool right? It needs to be forced on with some effort, as friction holds it at the proper adjustment. The nut is mostly for looks. Don't count on the nut to push the plate all the way on.
padgett on Sun October 02, 2011 8:36 PM User is offline
That is what I needed to know - had the remover but not the installer. FLAPS had no idea what I was talking about. Have a kit with proper installer tool on order now. Thank you.
Many Carpets
TRB on Sun October 02, 2011 8:46 PM User is offlineView users profile
Good point. I always assume people are using the required equipment.
91000-A
Edited: Sun October 02, 2011 at 8:47 PM by TRB
GM Tech on Sun October 02, 2011 9:05 PM User is offline
Just remember, you never thread into the hub when installing, only the shaft-- and vice versa..
padgett on Wed October 05, 2011 11:44 PM User is offline
And is now on. Took the proper tool and more force than expected. As mentioned the nut is just hanging in space, if you try to pull down with nut are liable to deform the edge of the clutch plate and then will not pull down period. If woodruff comes out, axle grease works to hold in. Have seen various specs but .025" is not dragging and pulls in well.
Thanks for the advice. Was a learning experience.
Many Carpets
GM Tech on Thu October 06, 2011 11:36 AM User is offline
The nut was never meant to adjust the clutch-it bottoms out onend of shaft- it was only there to protect the threads and keep shaft key in- and was completly eliminated in late 90's when bent keys were used....
