Toyota Previa Exploded AC Parts Numbers
540itouring on Mon September 05, 2011 4:11 PM User is offline
Year: 1996
Make: Toyota
Model: Previa
Engine Size: 2.4
Refrigerant Type: R134A
Hi , i worked on a UK Toyota 2.4 Previa with single AC system yesterday and found the minor leaks at last . The first leaks are from the two short metal pipes from the TXV to the main feed pipes / mounting bracket. The other leak is from the HP Compressor discharge hose to condenser. The first part of the hose is aluminium and has some minor pin holes in them.
I was looking for a exploaded view to enable me to find part numbers etc so i can confirm what parts i need before i call the dealer. I expect that these are main dealer parts only ?
It looks like these have corroded from the outside in and wonder if this is a common fault with toyotas and also other makes. I had to put dye in the system and then with a UV lamp was able to find the very small green dots where the leaks are.
Thank you for your help in advance.
HECAT on Tue September 06, 2011 8:01 AM User is offline
OE exploded view and part number information is available for a fee from the OE, Mitchell, Alldata, etc. It violates copyrights to freely share said info. Some will offer a very minimal fee for one day access to get the info you need.
