MitchR on Wed August 24, 2011 7:51 PM User is offline
For us amatuers who don't have a recovery machine, I thought I read an earlier post about using a 30 lb. tank put it in an ice chest pull a vacuum and recover some refridge that way. If so what would you guess you could recover? 50%? 75%. And also opening the gauge valve to a minimum keeping oil mix low. Has anybody ever done this?
Another question if you suspect your used vehicle may have had sealant put in, can you flush it out or need to replace?
GM Tech on Wed August 24, 2011 9:29 PM User is offline
This was standard procedure before recovery machines - but if you use just ice-- it's only 32 degf-- we always used dry ice-- much colder
mk378 on Wed August 24, 2011 9:34 PM User is offline
You'll need a recovery cylinder, not just an empty tank. Recent 30 lb tanks that refrigerant is sold in have a check valve so they don't refill.
Edited: Wed August 24, 2011 at 9:35 PM by mk378
