What to use to seal Evap box.
70monte on Thu August 04, 2011 12:34 AM User is offline
What do you guys recommed to reseal two halves of an Evaporator box back up and what can be used around the perimeter of the evaporator itself to make sure it is making a tight seal inside the box.
I don't recall the new evaporator have anything surrounding the outside perimeter to seal it against the inside of the evap box. Someone suggested to me that maybe the evaporator is not sealing inside the box and letting the hot inside air to go around the evap instead of through it, causing the vent temps to be high. Thanks for any info.
Wayne
70monte on Thu August 04, 2011 6:41 PM User is offline
Has no one here had to reseal an evap box?
Wayne
TRB on Thu August 04, 2011 6:49 PM User is offlineView users profile
Silicon and prestite tape works for us.
sevobuck on Thu August 04, 2011 11:13 PM User is offline
How about aluminum tape? It is super sticky, conforms easily, and is removal if you ever need to get back in.
70monte on Fri August 05, 2011 2:07 AM User is offline
Thanks for the help.
JJM on Fri August 05, 2011 9:10 PM User is offline
I like my 3M Strip Calk 08578:
Really neat and easy to apply, perfect width too. I've been using it probably since I was a kid. It also stores very well.
Good for covering up TXV sensing bulbs too.
Joe
70monte on Sat August 06, 2011 12:07 PM User is offline
Thanks Joe, someone else recommended this stuff to me and is what I plan on using.
Wayne
