clutch wont pull in
spongebob on Wed July 20, 2011 12:57 PM User is offline
Year: 87
Make: chevy
Model: s-10
Engine Size: 2.8
Refrigerant Type: r-12
i put a ground wire on one terminal and 12 volts off of battery to the other...wont ingage!!
is it shot? compressor is a ready aire 2394n
Cussboy on Wed July 20, 2011 2:24 PM User is offline
Disconnect the wire, read ohms resistance across that AC compressor clutch coil, post that.
Without that info, you may just have a "gap" issue. What happens if you wire it like you did, and then tap on the face of it with a hammer, does it pull in (engage) ?
bohica2xo on Wed July 20, 2011 2:25 PM User is offline
Have you checked the clutch gap?
What is the coil resistance of the clutch?
B.
Cussboy on Wed July 20, 2011 2:25 PM User is offline
Yeah !!!
Edited: Wed July 20, 2011 at 2:25 PM by Cussboy
spongebob on Wed July 20, 2011 2:41 PM User is offline
i got 3.6 ohms!!! *gulp*
give me a minute and ill try the hammer thing!!!
Edited: Wed July 20, 2011 at 2:42 PM by spongebob
spongebob on Wed July 20, 2011 2:50 PM User is offline
WOOT HOOO
i went to smack it and it came on by its self...i may of had a crummy ground...thanks guys..
