S10 Air Flow Problems
HogWinslow on Thu July 07, 2011 12:00 PM User is offline
Year: 2004
Make: Chevy
Model: S10
Engine Size: 4.3L
Refrigerant Type: 134A
Ambient Temp: 70
Pressure Low: 30
Pressure High: 160
2004 Chevy S10
185,000 miles
High Side reading is 160
Low Side reading is 30
Outside Temp is 70
I've never had A/C problems in the past. The air blew hard and was ice cold. About a week ago I noticed that the air flow seemed to get stronger and then lessen. It was no big deal, I still had A/C.
Well it has gotten worse. Now it goes from tons of air flow to none. I live in the mountains and I noticed that it reacts to the throttle position. When I go up the mountain and my foots into the throttle I get little air flow. But when I go down the mountain and I'm on the brakes I get good airflow. Last night I used the defroster to clean the windshield and it wouldn't put all the airflow to the windshield. It was still putting a good amount of flow to the dash vents.
I've read in past posts that somehow the 4X4 can effect the vacuum in the A/C. For the past two years I had a problem getting the 4X4 to lock in. About six months ago I engaged the 4X4 in the driveway and it made a huge bang so loud my wife came running out of the house to see what happened. I haven't had a problem with it since.
Any ideas on where to start?
GM Tech on Thu July 07, 2011 2:06 PM User is offline
Black vacuum line is cracked or broken near the check valve-- trace from vacuum reservoir back to intake port....
Edited: Thu July 07, 2011 at 2:06 PM by GM Tech
HogWinslow on Sun July 10, 2011 1:27 AM User is offline
Come to think of it, the truck is showing codes for a leak in the vent (evap) system of the fuel tank. I think it's a P0049. Would this have anything to do with the vaccum leak?
