oil charge
1yy07 on Tue June 21, 2011 4:54 PM User is offline
Year: 1979
Make: chevrolet
Model: corvette
Engine Size: 5.7
Refrigerant Type: r12
factory book says oil charge r4 6oz how much goes where
bromodragonfly on Tue June 21, 2011 5:41 PM User is offlineView users profile
Brand new system - into the compressor.
Compressor replacement - drain old oil from compressor, add same amount of new oil into compressor.
R12/R134A Retrofit - assuming accumulator/drier has been changed and lines/cond/evap are free of any logged oil, you would drain compressor and add 6oz of new oil to it.
Dougflas on Tue June 21, 2011 7:59 PM User is offline
New R4's I put mineral oil in them (couple of oz), let it sit clutch down on bench, drink a beer, turn compressor a few turns, drain oil well, add proper amounr of ester oil. This will lube the seal. IT has worked for me for many years.
GM Tech on Tue June 21, 2011 10:40 PM User is offline
New R4s, I install PAG oil mixed with dye- mount compressor drink a beer while vacuum pump runs, charge it and run- never turn it, never worry about double lip seals-- works for me for over 20 years....
