2004 Chevy Avalanche
jgcox6 on Tue June 21, 2011 8:21 AM User is offline
Year: 2004
Make: Chevy
Model: Avalanche
Will someone tell me the proper clutch gap for a 2004 Chevy Avalanche AC compressor? It has the typical works fine for till the engine gets good and warm...then the clutch lets loose. I can tap it with a screw driver handle and the clutch reengages....
GM Tech on Tue June 21, 2011 8:54 AM User is offline
Remove clutch driver- then remove the thickest shim-- gap should be near .020"...
jgcox6 on Wed June 22, 2011 8:43 PM User is offline
i thought the compressor clutch on this vehicle just needed to be "pressed" closer to the compressor. Not shimmed like a FORD is it?
