how can you bypass compresser
jfranciose on Wed June 08, 2011 8:53 AM User is offline
Year: 1997
Make: buick
Model: laseber custom
Engine Size: 3.8
if compresser is not comming on due to low freon how would you get around to filling freon compresser and all parts are new
mk378 on Wed June 08, 2011 9:46 AM User is offline
Don't start new threads about the same problem, don't call R-134a "freon", and don't "bypass your compressor".
jfranciose on Wed June 08, 2011 10:45 AM User is offline
excuse me for sayng freon i guess its a girl thing so sorry also im not stupid i know you cant bypass a compresser what im asking is how to fill compresser with r134a if its to low for compresser to cut on . its in the green with half can of r13 if i add anymore it will be in the red now do i need shop to fill it or is there a way to do this myself thank you
Cussboy on Wed June 08, 2011 2:34 PM User is offline
OK. We don't recommend adding refrigerant without using a set of gauges for both low and high side pressures. That technique can usually get one close.
However the best way is to evacuate and fill by weight (e.g. at a shop). But since it is likely your refrigerant has leaked out, the leak needs to be fixed or the added refrigerant will leak out as well.
GM Tech on Wed June 08, 2011 2:36 PM User is offline
Compressor comes on when the refrigerant is added...no need to bypass anything.
jfranciose on Wed June 08, 2011 5:49 PM User is offline
thanks frigerant didnt leak compresser blew from inside had metal in everything put all new parts thats why air in line
