If the high side is high can the compressor be bad?
Briandl79 on Tue May 31, 2011 2:09 PM User is offline
Year: 2006
Make: Jeep
Model: Commander
Engine Size: 5.7
Refrigerant Type: R134A
Ambient Temp: NA
Pressure Low: NA
Pressure High: NA
Say you're having problems with your AC not cooling and the charge is correct. You've replaced a few things and the other possibilities are the compressor, drier, or maybe the condenser. If the high side reads a high pressure within specs, does that rule out a problem with the compressor?
iceman2555 on Tue May 31, 2011 10:27 PM User is offlineView users profile
A bit more information would be helpful. First how did you determine the system was 'charged correctly'? What pressures are being encountered? What problems are being experienced? Provide a more detail explanation of 'problems' and we maybe of more assistance.
mk378 on Wed June 01, 2011 8:27 AM User is offline
Don't start a new topic about the same problem. Add to your old one.
