Recharge / Oil in Sanden Custom System???
terrytruett on Thu May 26, 2011 8:58 AM User is offline
Good morning guys!
I have a custom Hot Rod system using a Sanden 508 Compressor. After beginning to charge system I had one fitting that I had failed to completely tighten, so had a leak for a bit and not sure how much 134 I lost. System is cooling well but no doubt I put too much due to guessing at level due to leak. Compressor sounds like rocks on start up, but after on and off a couple of times it runs fine.
So, question being; When I start removing 134, and/or completely remove and re evacuate system, in either case do I need to add any more oil to system?
Thanks in advance!
tt
TRB on Thu May 26, 2011 9:42 AM User is offlineView users profile
How much oil did you start with. How much oil was lost? Add back the guesstimate. Reclaim refrigerant and recharge to the suggested amount by your supplier.
