2001 Honda Civic TRSA09 compressor isn't compressing
brucem on Sat May 21, 2011 3:13 PM User is offline
Year: 2001
Make: Honda
Model: Civic
Refrigerant Type: 134A
Ambient Temp: 80f
Pressure Low: 95
Pressure High: 95
The clutch is DEFINITELY engaging. Visual verification! However pressures do not change. Low side 95psi, high side 95psi before engaging clutch. After engaging clutch, pressure drops slightly on both sides. I assume due to fan drawing air through condenser.
It sure looks like the compressor needs replacing. Does the lack of pressure change indicate that the compressor has spewed it's innards into the systems and would this require exhaustive flushing or extensive component replacement?
Or is the clutch just bad? Also can this compressor be rebuilt by a fairly competent DIYer.
Thanks in advance...bmf
Edited: Sat May 21, 2011 at 3:32 PM by brucem
GM Tech on Sat May 21, 2011 4:54 PM User is offline
heck the inlet of your expansion device, that will tell you f system is trashed. I usually just remove compressor and open it up to determine failure mode- then decide what to do. It's called an autopsy.
brucem on Sun May 22, 2011 2:14 PM User is offline
Thanks for your input. bmf
iceman2555 on Sun May 22, 2011 7:24 PM User is offlineView users profile
No one wants to hear the cost of any AC repair and the list of parts necessary to complete the repair. This is one of those that can drive most off the 'deep end'. The failure of this compressor is often so severe that in most cases the entire system should be replaced. The condenser is a must...the evap can normally be flushed and cleaned but considering the age and mileage of this vehicle it may be best to simply replace it. The TXV should be replaced,the hose/manifold should be flushed and cleaned completely. Be sure that the system is lubed and recharged properly. Failure to properly charge this system will result in a repeat failure and of course requires the expenditure of most cash. The scroll compressor utilized on this vehicle is a great performed...but when it fails....the system does become highly contaminated.
Good luck with your repair.
brucem on Mon May 23, 2011 10:18 AM User is offline
iceman- Thanks for your insight and info. bmf
ice-n-tropics on Mon May 23, 2011 3:07 PM User is offline
If the high side goes down, are you plumbed back-ass-wards?
hotrodac
brucem on Tue May 24, 2011 7:54 AM User is offline
Thanks for the reply. I haven't changed the plumbing and it used to work just fine...bmf
Biscuit on Sat June 04, 2011 6:01 AM User is offline
Did you look for a blown compressor gasket?
