97' Dodge Ram Low Pressure Cutoff Switch
rnoecker on Thu May 19, 2011 5:14 PM User is offline
Year: 1997
Make: Dodge
Model: Ram
Engine Size: 5.9Diese
Refrigerant Type: R416A
I have replaced 134a with 416a refrigerant. 416a runs at a lower pressure than 134a. My question is how do I change the low cutout switch setting from 24 to 19psi? I called the Dodge dealer and thay told me that the low cutout switch is not adjustable. Do thy make an adjustable low pressure cutout switch?
Robert K. Noecker
mk378 on Fri May 20, 2011 7:59 PM User is offline
R-416a should not be used in factory R-134a systems. It contains chlorine in the R-124 component of the mixture, which is incompatible with PAG oil.
rnoecker on Sat May 21, 2011 10:47 AM User is offline
Robert K. Noecker
rnoecker on Sat May 21, 2011 10:48 AM User is offline
I currently have 416a in the 134a system. What do you recommend my next steps should be to correct the issue?
Robert K. Noecker
