'89 Town Car oil
rhb1999 on Wed May 11, 2011 3:19 PM User is offline
Year: 1989
Make: Lincoln
Model: Town Car
Engine Size: 302
Refrigerant Type: r-134a
Hello, I'm kinda new here. Sorry, but I have to ask a stupid question. Does anyone happen to know how many ounces of oil (pag 46?) should be in an retrofitted sytem, on a '89 Lincoln Town Car? I believe the r-12 charge is 3 lbs 2ozs., plus the amount of for the oil?, also what are the high and low side readings for this car. Thanks in advance.
Edited: Wed May 11, 2011 at 4:42 PM by rhb1999
Chick on Wed May 11, 2011 4:43 PM User is offlineView users profile
My personal preference is BVA Auto 100 ester oil for retrofits.. If using Pag, then 46 is the the one.. Use 8 ounces on a flushed empty system.. Pressures will fluctuate with outside temps and humidly. Post your pressures along with the outside temp and humidly and we'll check it out.. As I said, the BVA is my choice, and never had a problem with it....But it's your choice... Hope this helps...
rhb1999 on Wed May 11, 2011 5:42 PM User is offline
80% of 3lbs 2oz. plus 8 ounces for a total R-134a charge. Thanks.
TRB on Wed May 11, 2011 5:52 PM User is offlineView users profile
Compressor Type
Crown Victoria & Grand Marquis 6E-171 6-Cylinder
Town Car FS-6 6-Cylinder
1989-90 10PA17 10-Cylinder
Compressor Oil Capacity
FS-6 Compressor 10 oz. (296 cc)
6E-171 Compressor 13 oz. (385 cc)
10PA17 Compressor 5 oz. (148 cc)
Refrigerant (R-12) Capacity
FS-6 Compressor 48 oz. (1.36 kg)
6E-171 Compressor 52 oz. (1.47 kg)
10PA17 Compressor 48 oz. (1.36 kg)
System Oil Capacity 8 oz. (236 cc)
System Operating Pressures (1)
High 160-250 psi (11-18 kg/cm2 )
Low 25-50 psi (2-4 kg/cm2 )
(1) Measured at 80°F (27°C) outside temperature.
rhb1999 on Thu May 12, 2011 10:24 AM User is offline
Thanks, TRB. Is there any real difference between the 10pa17 and the 10pa17a?
Edited: Thu May 12, 2011 at 11:49 AM by rhb1999
