99 Cavalier...Delphi Compressors?
aegis on Sun April 24, 2011 1:17 PM User is offline
Year: 1999
Make: Chevy
Model: Cavalier
Engine Size: 2.2
The clutch bearing went out on my compressor over a year ago and the AC started blowing hot shortly after. I plan on replacing the compressor, accumulator and orifice tube myself, and I'll bring it to a mechanic to vac and charge the system.
I was planning on purchasing a Delphi compressor, but I was wondering if anyone here has any experience with that particular brand. Good or bad? Also, how much PAG oil does the compressor require (the Delphi compressor is shipped dry)? Does the accumulator or any other component require PAG oil as well?
Edited: Sun April 24, 2011 at 1:18 PM by aegis
GM Tech on Sun April 24, 2011 1:32 PM User is offline
System oil capacity is 9.0 ozs--- So you must figure out if you are flushing, or just replacing components- how much oil to re-install. The V-5 compressor usually hold 3 - 3.5 ozs in its crankcase-- the accumulator hold about 3 ounces, most of it is saturated and soaked up into the internal desiccant bag.
