Tercel pressures?
Kolbergk on Tue April 19, 2011 8:06 PM User is offline
Year: 1996
Make: Toyota
Model: Tercel
Engine Size: 1.5
Ambient Temp: 85
Pressure Low: 44
Pressure High: 180
My daughter complained of the AC not cooling. These are the pressures I got while it was 85 out. The vent temp was 56 with doors open.
I took the car for a drive afterwards and the vent temp dropped to 44 degrees (windows shut, max fan, recirculating, cloudy out) I think she's just
being a girl. Do those pressures look right? Thanks!
TRB on Wed April 20, 2011 11:26 AM User is offlineView users profile
SPECIFICATIONS
Application Specification
Compressor Type Matsushita TV12C Rotary Vane
System Oil Capacity (3) 3.4-4.1 ozs.
Refrigerant (R-134a) Capacity 22.9-26.5 ozs.
System Operating Pressures (4)
High Side 199-228 psi (14.5-15.0 kg/cm2 )
Low Side 21-36 psi (1.5-2.5 kg/cm2 )
(4) When ambient temperature is 86°-95°F (30°-35°C).
Kolbergk on Sun April 24, 2011 7:44 PM User is offline
OK, thanks for the data. Of course it brings up other questions. Are those pressures based on idle speed or something higher? Thanks again. Ken
