Where is all a my oil
loritom62 on Mon March 14, 2011 8:19 PM User is offline
Year: 98
Make: chevy
Model: venture
Engine Size: 3.4
Refrigerant Type: r134
I changed my compressor,orifice tube and accumulator of all these components i only managed to drain about 25 drops of oil.I was wondering if i should add more oil or just leave it like it is.The old compressor had a seal leak and lost all the r134. The new compressor already had 1.5 ounces in it.Thanks for the help.
GM Tech on Mon March 14, 2011 9:38 PM User is offline
Did you open the drain bolt from the crankcase of the compressor? There should have been nearly 3 ozs in there alone.
I have seen mechanics try to drain the oil from the V-5 compressor out the ports--not realizing there is a crankcase designed to hold oil.
Also, there is at least 2-3 ozs of oil soaked up into the desiccant bag of the old accumulator-- to be sure, weigh the old versus the new A/D. (if they are the same design)
Cussboy on Mon March 14, 2011 11:16 PM User is offline
Couldn't your oil loss be out that compressor seal ???
HECAT on Tue March 15, 2011 7:28 AM User is offline
Even with the V5 crankcase; oil migration becomes compromised as the refrigerant charge drops (leak). The critical oil migration point that requires a proper charge is inside the evaporator, and this is where the oils will often pool.
HECAT: You support the Forum when you consider for your a/c parts.
NickD on Tue March 15, 2011 9:52 AM User is offline
Tis nice the sump in AC compressors was reinvented, some always stays in there to help prevent catastrophic failure that we have become accustomed to with the demise of the A-6.
But then also blessed with PAG oil that is made out of the stuff women slap all over their face with. If you want to see what PAG sludge looks like, don't have to go any further than your bathroom sink. Now I am wondering if I should swipe my wifes' facial soap to flush out my MVAC system with, seems to do a good job on her face.
But anyway, best to replace the dryer, drain and flush the compressor with fresh PAB, and flush out the rest of it. I like to draw a deep vacuum first before injecting the new PAG.
Payment for you doing this will be having a system that lasts more than two weeks.
