Poor cooling.need help
famesethu on Fri March 11, 2011 9:58 AM User is offline
Year: 1995
Make: Suzuki
Engine Size: 1.1L
Refrigerant Type: R134
Country of Origin: India
hey guys
i recently charged my a/c from empty.now the cooling seems to be low now than before.I think i overcharged my a/c.
AC OFF
Low side pressure= 100psi
AC ON
Low side pressure = 60psi.
TXV,dryer,compressor all new.
AC cools but less cooling than before.
mk378 on Fri March 11, 2011 9:18 PM User is offline
The high side pressure needs to be measured to properly evaluate the situation.
Did you evacuate the air before recharging? If you take apart a system and then just dump refrigerant in without using a vacuum pump to get the air out of the lines first, you end up running a mixture of air and refrigerant which will not cool properly.
Did you add or remove any oil? Always charge an empty system by weight starting from a deep vacuum. Use the manufacturer's specified amount of refrigerant measured by weight.
