Compression fitting on hard line
emsvitil on Thu September 16, 2010 4:12 PM User is offlineView users profile
Year: 1986
Make: Toyota
Model: Pickup SR5
Engine Size: 2.4
Refrigerant Type: R12
Ambient Temp: NA
Pressure Low: NA
Pressure High: NA
I have a high side pressure line (drier to evaporator) that was installed incorrectly 24 years ago by the dealer when I bought the truck. (A section was installed above a wiring harness instead of below the wiring harness, and the harness wore a hole into the line).
Anyway, why couldn't a high-pressure compression fitting (1000psi) be used to splice the line at the hole? I don't see how it would leak....
Don't ever intend to take it apart there, and the fitting is only about $3.......
Ed
SoCal
GM Tech on Thu September 16, 2010 4:24 PM User is offline
That's what the inline filters use---you are directed to cut the line apart and install a compression fitting as part of the in-line filter. Personally, I prefer the swageloks-- work really good.....
HVargas on Thu September 16, 2010 4:33 PM User is offlineView users profile
As GM Tech stated, the Inline Filter is designed to do just that. To couple into the aluminum line with compressor fittings.
Contact: Arizona Mobile Air
emsvitil on Thu September 16, 2010 5:42 PM User is offlineView users profile
Cool....
Pity it's already after the filter/drier.......
Ed
SoCal
wgabriel10 on Thu September 16, 2010 8:30 PM User is offline
And if you have my typical luck, I suppose the hole is far enuff from the filter that you could not cut the line just past the hole and still have enuff slack in the rest of the line to put a new fitting on the line where you cut it and still reach the filter connection! Bummer for sure if you cannot do that. You could use some fittings and the same size tubing to extend the line enuff to reach the filter. That might be simpler/cheeper than replacing the complete tubing run.
My heart goes out to you!
Watson
wgabriel10 on Thu September 16, 2010 8:48 PM User is offline
Ed -- I just had a brain fart! Am wondering if you might have misunderstood the other guys that answered you. What they were saying is to use a coupling to just make a splice in the line where the hole was. That would be mucho better than what I was thinking in my previous answer for sure. Whether or not you could do this depends on where the hole is in relation to the filter -- you would have to have enuff room for the fittings. If that won't work, you could do what I suggested in my first post. You would have to find a piece of the same sized tubing to use with the fittings.
Watson
emsvitil on Fri September 17, 2010 2:59 AM User is offlineView users profile
You get about an inch of length with the coupler.
That, plus the line is convuluted (you can gain a little length by slightly bending the line and taking a slightly different path) will get me what I need to get rid of the bad section.....
thanks
Ed
SoCal
NickD on Fri September 17, 2010 7:03 AM User is offline
It took 24 years to discover that problem? Thought I was slow.
emsvitil on Fri September 17, 2010 7:28 PM User is offlineView users profile
It took awhile to wear enough of the tubing away to cause a leak.........
Ed
SoCal
