Pag 46 compatability
ugmw177 on Thu August 26, 2010 3:50 PM User is offline
Is PAG compatible with both r12 and r134a?
HVargas on Thu August 26, 2010 4:29 PM User is offlineView users profile
No only R134a and even then it should only be used in specified vehicles.
Contact: Arizona Mobile Air
ugmw177 on Thu August 26, 2010 8:26 PM User is offline
ok, thanks...i purchased a new compressor to use with my r12 system but the manufacturer ships it preloaded with PAG46...if i want to run r12, is it ok to drain the compressor [sanden SD507] and fill with either esther or mineral or do i need to clean the compressors' resovoir somehow? I know i cannot flush a compressor
TIA
HECAT on Fri August 27, 2010 5:34 AM User is offline
compressor flushing procedure
Cussboy on Fri August 27, 2010 3:40 PM User is offline
TIA
I had similar situation. The rebuilt compressor for my '88 B2200 truck (from this board sponsor) came pre-loaded with a PAG oil (I tested it at work, infrared spectrophotometer, FTIR). I drained out the PAG oil, filled it with refrigeration mineral oil, rotated the compressor through several cycles, then drained, repeated, then drained again and added the correct amount of mineral oil. This was approximately 2003, and it's still running great (practically every day, Arizona).
