Refrigerant charge capacity
dave76 on Tue August 03, 2010 7:52 PM User is offlineView users profile
Year: 1999
Make: Chevy
Model: Tahoe
Engine Size: 350
Ambient Temp: 88°F
Looking for the proper charge amount, because the accumulater sez 2lbs 12oz for Tahoe, Suburban 3lbs 8oz. After reading the threads here it seems the proper charge is 64oz with rear which I have.
GM Tech on Tue August 03, 2010 8:15 PM User is offline
my chart says 64 oz
dave76 on Tue August 03, 2010 9:39 PM User is offlineView users profile
Alright 7 cans of 134a, then.
Anyway the A/C works fine, just that I see oil leaks out of the low side cap on the compressor and upon removal of the cap you get that little puff of gas. I put my gauges on and got at 2000 RPM about 30 PSI low, and 230 PSI high @ 88°F ambiant temp, about 43-45°F register temps, and 50-53°F at idle. My plan is to reclaim the refrigerant, replace the schrader valves, pull a vacuum for and hour and recharge it. Question, should I replace the orfice tube while doing this?? I also insulated the suction line with extra insulation including the muffler. This truck still has the stock HT6 compressor, but it dosn't seem to be leaking.
dave76 on Wed August 04, 2010 5:46 PM User is offlineView users profile
Bump
dave76 on Thu August 05, 2010 5:04 PM User is offlineView users profile
dave76 on Thu August 05, 2010 5:13 PM User is offlineView users profile
Well I recovered all the charge, replaced the low side schrader, looks like highside valve will need replacing, will do next year. Pulled the OT it was a greyish color, woundering if the compressor is on it way out? Next year I would like to rebuild the whole system.
Anyway I charged the sytem with 5 cans and 4oz out of the 6th, it's running awsome now, I did notice the suction line from the rear evap all the way to the front sweats like hell, would probably be a good idea to insulate it??
