GM Sealing Washers - Oldsmobile Intrigue
nyc951 on Tue July 20, 2010 9:18 PM User is offline
Year: 2001
Make: Olds
Model: Intrigue
Engine Size: 3.5
Hi,
I am going to work on my father's Oldsmobile Intrigue and have a question about the o-rings and GM sealing washers. Which a/c components use the GM sealing washers? I will only be opening up the connections for the hose at the front of the car (can't remember if it's the high or low pressure one, but nevertheless) to seal it with Nylog. I mechanic who replaced it most likely didn't use Nylog and I suspect that's why the refridgerant has all leaked out.
'98 328i
Chick on Tue July 20, 2010 9:40 PM User is offlineView users profile
If you open a line you suspect of leaking, change the O rings or sealing washers.. If sealing washers, don't use the nylog, no need for it, but use it on "new" O rings..
nyc951 on Tue July 20, 2010 10:08 PM User is offline
Thanks Chick.
Generally, which components or lines in the GM cars use those sealing washers?
'98 328i
70monte on Tue July 20, 2010 10:36 PM User is offline
My experience has been that where the manifold lines hook up to the compressor, is where the sealing washers are used. All of the other connection points on GM vehicles I have seen use the o-rings.
Wayne
Chick on Tue July 20, 2010 10:41 PM User is offlineView users profile
It depends on the model car, I can remember as far back as '95 Caprice using sealing washers on lines to the evap, others use O rings, you can tell which lines have sealing washers because they will attach to a "block" not a fitting.. I can't remember off hand where on your car they will go.. And of course the rear of the compressor..
GM Tech on Tue July 20, 2010 10:58 PM User is offline
Sealing washers came in on GM cars in early 90's- even before r134a........so every GM compressor since then uses them......best thing for a sealed joint- much better than o-rings....your intrigue will use them throughout the a/c system.
Be aware the intrigue may have the blasted control head a/c flicker issue...
nyc951 on Thu July 22, 2010 12:12 AM User is offline
Thanks guys.
Do connections where sealing washers are used require any special tools, or just your simple wrench/socket?
'98 328i
Chick on Thu July 22, 2010 6:37 PM User is offlineView users profile
Simple wrench/socket....
GM Tech on Thu July 22, 2010 7:07 PM User is offline
You'll need to hold the manifold from twisting with vice grips or such...
nyc951 on Fri July 30, 2010 9:17 PM User is offline
Thanks folks. I will be working on the car this weekend.
What's the Low and High side pressures I should aim for on this Olds Intrigue? I know it will be temperature dependent, but a ballpark number would be helpful.
'98 328i
Chick on Fri July 30, 2010 10:49 PM User is offlineView users profile
Vacuum system, fill by weight, the pressures will just tell you if something is wrong...
