97 suburban pressure reading please help
bluef4i on Fri July 16, 2010 6:16 PM User is offline
Year: 97
Make: chevy
Model: suburban
Engine Size: 350
Ambient Temp: 90
Pressure Low: 50
Pressure High: 200
are these readings right im only getting 64degrees at the front vents and about 75 at the rear vents
Tennessee_Timmy on Fri July 16, 2010 6:31 PM User is offlineView users profile
just a quick thought until the experts get by (excerpted from a post by [email protected] earlier today):
"That is why when a system goes low, you will usually notice the rear air blowing warm before the front."
Good Luck 2 ya,
GM Tech on Fri July 16, 2010 7:15 PM User is offline
1) Does compressor turn easily-- like with just one finger? 2) Can you detect little"catches" as you rotate it? 3) Does it ever cycle off when blower is on low fan speed? 4) does suction pressure ever come down close to 25 psi when blower is on lowest setting/inside air?
If 1,2 are yes and 3 and 4 are no- then you probably have a suction reed failure n your compressor-- otherwise known as "imploded" look for stainless stell shrapnel in your orifice tube...and the need for a new compressor....
