QUICK COUPLER QUESTION
77shovelhead on Thu July 15, 2010 10:34 PM User is offline
I received my new DIY kit today and while looking it over I noticed that the quick couplers had a brass ring inside that prevents the balls from moving, which prevents the sleeve from sliding more than 1/16". This ring rest on the o-ring and extends to the center of the 6 balls. It seems like the ring should be removed so that the sleeve can slide down to the snap ring.
Is this common or am I missing something?
Quality is never an accident it is always the result of intelligent effort.
TRB on Thu July 15, 2010 10:55 PM User is offlineView users profile
When the coupler is pressed on the fitting it will depress the coupler allowing it to seat correctly.
77shovelhead on Thu July 15, 2010 11:08 PM User is offline
Better to ask just in case. I've never seen this set up before.
Thanks TRB.
