recovering refrigerant - do you get oil?
Rodney R on Sun July 11, 2010 3:31 PM User is offline
If you recover the refrigerant out of a vehicle, do you get any oil from the system in the recovery tank? Will I need 2 recovery tanks for 134a (one for PAG and one for ester oil), or do I only get refrigerant?
Rodney
'92 Ford F-250, 7.3 diesel
chris142 on Sun July 11, 2010 7:17 PM User is offline
My machine always brings some oil out. Usually less than an ounce unless the system is flooded with oil. If it's flooded I've seen it pull 6 ounces out.
Dougflas on Sun July 11, 2010 7:19 PM User is offline
If you recover from the low side, you will only pull vapor and no oil. There is a difference between a recovery machine and a reclaimer machine. Reclaimers have oil separators in them.
CCWKen on Sun July 11, 2010 11:51 PM User is offlineView users profile
My recovery machine has two filters. One on the intake hose and another larger filter/drier before the tank hose. They may pull some oil but the intake filter catches nearly all of it. And these are relatively cheap and a snap to replace. If you don't already, run at least an intake filter. It can save your recovery machine a lot of grief if you happen to be recovering from a dirty system.
Ken Kopsky
Custom Car Works
Rodney R on Mon July 12, 2010 7:40 PM User is offline
I'm using a promax RG5410A, and I recovered from the high side (per the instructions). I do have a filter on the intake.
