Toyota AC pressure and vent temp
Sixseas on Sat July 10, 2010 2:46 PM User is offline
Year: 2000
Make: Toyota
Model: Echo
Engine Size: 1.5L
Ambient Temp: 80
Hi, I have a 2000 ECHO and will likely run it across the Mojave next month and want to make sure shes working at full capacity.
Does anybody have the AC test procedure, vent temps and High and Low pressure by ambient temperature? Also if you can refresh my memory on using the site glass, it foams a bit when the compressor clicks on but is otherwise clear. I asked the local dealer they had no idea or wouldn't tell me. Thanks
TRB on Sat July 10, 2010 2:51 PM User is offlineView users profile
Application Specification
Compressor Type SCS06 Scroll
Compressor Belt Deflection (1)
New Belt 9/32-21/64" (7.0-8.5 mm)
Used Belt 7/16-33/64" (11-13 mm)
System Oil Capacity (2)
Refrigerant (R-134a) Capacity 15.2-17.3 ozs.
System Operating Pressures (3)
High Side 199-228 psi (14-16 kg/cm2 )
Low Side 21-36 psi (1.5-2.5 kg/cm2 )
(1) Measured on longest belt run. A new belt is one that has been used less than 5 minutes.
(2) Check underhood A/C specification label. Use ND-OIL 8.
(3) Specification is with ambient temperature at 86-95°F (30-35°C) and 1500 RPM engine speed.
Sixseas on Mon July 12, 2010 12:30 AM User is offline
Great now I can check it out during the week. Thanx
