Year: 1990
Make: chevrolet
Model: k1500
Engine Size: 5.7L
Refrigerant Type: R134
I want to replace the expansion valve in my 1990 k1500, but I am not able to find it. According to the Chevrolet C/K pickup Service Manual, it is located in the evaporator inlet line. I have removed the accumulator and disconnected the line that runs from the condenser to the evaporator inlet, but did not find the expansion valve. There does not appear to be any other place in the line between the condenser and the evaporator where the line can be opened.
My manual has the steps for the replacement of other AC components, but not the expansion valve. Can someone tell me where it is and how to replace it.
thanks
Should be a condenser mounted orifice tube.
condenser outlet behind right turn signal lense
As stated, behind the right turn signal lens, remove the light and you'll see the fitting where it's in..
