Condenser: Tube-and-fin or Parallel Flow
Chewed 71'er on Sun July 04, 2010 4:43 PM User is offline
Year: 1993
Make: Oldsmobile
Model: Cutlass Ciera
Engine Size: 3.3
I understand the folks at Arizona Air have used their products on their own fleet vehicles (and what better environment: Arizona). Due to the nature of 134a, it was noted that a parallel flow condenser provides better cooling than tube-and-fin or serpentine units. Is there any evidence that this contributes to compressor longevity? Admittedly, this may have little effect, as condenser is 'downstream' of compressor. Also, which is a better lubricant, BAV 100 or PAG? Thanks for your comments.
TRB on Sun July 04, 2010 6:05 PM User is offlineView users profile
A veined PF condenser allows is for a system designed with R12 components! The ability to have proper heat reduction with the OEM spec on refrigerant! That is what allows for longevity of the compressor. Proper oil amount and refrigerant to carry it though out the system. Oils can be debated all day by chemists. We have had great results over 15 years now using the BVA in both conversions and OEM R134a systems.
PS: Our company is Arizona Mobile Air. There is an Arizona Air but not sure what oil they use with their products.
Edited: Sun July 04, 2010 at 6:06 PM by TRB
Chewed 71'er on Mon July 05, 2010 4:24 AM User is offline
Thanks for info, TRB. Thank you for company name correction as well.
iceman2555 on Mon July 05, 2010 8:19 PM User is offlineView users profile
BVA markets both PAG's and POE's. BVA is a ISO certified company that produces chemicals for major OE markets as well as the aftermarket. The choice between PAG's and POE's has and will continue to be a subject of much discussion. However, BVA produces the best lubricant chemicals in the market today, IMLTHO.
