? for HECAT
Herb on Mon June 28, 2010 3:40 PM User is offline
HECAT, will be probably flushing a 2001 Peterbuilt this weekend w/your machine. Excellent tool. I have one gallon of your flushing solvent and am getting an order together for AMA. I'm doing this job for free for a very good, hard working man w/little money. I'm sorta broke too. How much do you recommend? See "Weak Pete" in forums please to see what is going on. Thank you, Herb
HECAT on Mon June 28, 2010 5:07 PM User is offline
Not knowing how big the components are, not getting to inspect this job myself, not knowing many things, leaves me with little option than the standard answer; 1-2 gallons per component, more if necessary.
Herb on Mon June 28, 2010 6:06 PM User is offline
Thank you, 2 gallons it is. Herb
HECAT on Mon June 28, 2010 9:32 PM User is offline
Reading back at the "weak Pete" post. You should have plenty to flush out the excessive oils. Make sure components are clean and completely DRY before putting it all back together. Thanks for the compliment/confidence in the tool you purchased. Good Luck.
Herb on Mon June 28, 2010 9:45 PM User is offline
Thank you. Herb
