2002 jetta AC inop
TucsonVTXF on Sat June 26, 2010 11:29 PM User is offline
Year: 2002
Make: volkswagon
Model: jetta
Engine Size: 2.0
Refrigerant Type: r134a
Ambient Temp: 95
Pressure Low: 150
Pressure High: 150
no power going to compressor!?!?! Fuse is ok. 13.5 volts at the low/high side switch. AC is serviced with the proper amount of r134a via my ACR2000. both cooling fans are on and running. I think it is the low/high switch is bad what do you think?? does the power run thru the pressure switch down to the compressor? thanks
Chick on Mon June 28, 2010 7:36 AM User is offlineView users profile
did you check the compressor relay? the switch sends information to the computer. make sure control head is sending request to the computer to turn it on..
TucsonVTXF on Wed June 30, 2010 8:52 PM User is offline
everything checked fine but the 11 volts refrence to the relay box from the computer for wide open throttle, engine over heat. etc... I punted and had them take it to the dealer
