AC
ridinhigh98 on Fri June 25, 2010 12:42 PM User is offline
Year: 1998
Make: Chevrolet
Model: k1500
Engine Size: 5.7
I have a weird ac leak. It only leaks enough to kick off the compressor. When you recharge it, the system only will take less than a can to bring it back to operating pressure. What could the problem be?
mk378 on Fri June 25, 2010 1:02 PM User is offline
Can you find the leak? Look for oil and / or dye if dye is installed in the system. Check the compressor shaft seal and case joints those are common leaks on GM trucks.
