Debris in the system
autowize on Wed June 23, 2010 7:55 PM User is offline
Hi Guy's Since flushing will not remove all the metallic Debris in the system, Do you think in line filter Cod:13128TSI will .
HECAT on Wed June 23, 2010 9:25 PM User is offline
A mesh screen will remove larger particulates from the stream; of course this is dependant upon the mesh size, and smaller particulates will pass. Excessive particulates will clog a mesh and or restrict proper refrigeration and lubrication circulation. If the flushing methods used cannot remove all the metallic debris, I would be looking at better flushing methods or component replacement. However, I do believe that after proper flushing and confirmation has been done, the additional insurance of a filter cannot hurt, with the exception of creating additional potential leak points in the system.
