Compressor to Condenser Hose
reedyd on Mon June 21, 2010 8:19 PM User is offline
Year: 1988
Make: Ford
Model: E-150 Econoline
Engine Size: 302
Ambient Temp: 100
On the hose going from the Compressor to the condenser ( discharge hose ) there is a aluminum canister in line with the hose. Is this a drier or muffler?
Also on a retrofit should I change the compressor cut out switch?
David
David W Reedy
Edited: Fri April 29, 2011 at 1:47 PM by reedyd
TRB on Mon June 21, 2010 10:03 PM User is offlineView users profile
Compressor to cond would be the discharge line. The canister in that line would be a muffler. No adjust the one you have if needed.
Edited: Mon June 21, 2010 at 10:04 PM by TRB
reedyd on Tue June 22, 2010 2:53 PM User is offline
I have pretty much replaced the complete system. I have a new compressor YC-53 /w clutch 99.00, accumulator 12.95, manifold 45.00 , orifice 2.00 , parallel flow condenser 109.00 and a couple of hoses 25.00 I blocked off the rear AC.
1.It looks old. No I left it the muffler in the discharge hose
2. I blocked off rear AC
3. New Green O rings and Spring lock clamps
Also added heavy duty fan clutch
I am currently getting 40 from my ac and I would like to get lower but that is good enough for me.
Anyone have any questions please let me know
David W Reedy
Edited: Fri April 29, 2011 at 1:43 PM by reedyd
