Compressor Oil Confusion
4.0_olds on Wed June 16, 2010 8:17 PM User is offline
I'm trying to get my A/C system working in a small farm tractor and there is some confusion on compressor oil. The tractor uses a small Harrison/Delphi model SP-10 ten piston compressor.
The plate on the side of the compressor specifies Dow Chemical UCON 244 oil which I think is a PAG100. The Dow data sheet says 100 viscosity at 40 degrees C.
The service manual for the tractor specifies PAG46.
Which one should I use????
The quantity of oil on the compressor information plate is 8 ounces which would probably fill the compressor to the top. Do I pour all 8 ounces into the compressor and will most of it leave the compressor and distribute into the rest of the system?
http://www.dow.com/PublishedLiterature/dh_004d/0901b8038004d7fb.pdf?filepath=ucon/pdfs/noreg/118-01581.pdf&fromPage=GetDoc
Thanks for any help
TRB on Thu June 17, 2010 11:01 AM User is offlineView users profile
I would use PAG 100 and adding the 8 ounces to the compressor is fine. Juts turn the clutch hub a few times to move a little around before charging.
4.0_olds on Fri June 18, 2010 12:00 AM User is offline
Thanks, I will do that. Could you or anyone else double check the Dow link I posted and make sure I'm reading it correctly. It doesn't actually say PAG100 but I'm looking at the viscosity and assuming that is what the 100 means.
