Best way to separate case sections on V5 Compressor (trying to replace V5 case orings)
govan22 on Sun June 13, 2010 4:30 PM User is offline
Year: 1998
Make: Buick
Model: Century
Engine Size: 3.1a V6
I have a V5 Compressor and would like to replace the two large case orings (also called case "belly" rings).
I have removed the shaft seal, hub/pulley, coil and front bolts. It appears the V5 Compressor has a front half
(head) and a rear half..and a center section (case)...the front and rear parts slide over the center section.
I have read that corrosion can get into the area where these front/rear sections slide over the middle
case section...
I have put the compressor in a vice and tried to gently twist and pull the front section off the case...
but no luck...
should i use a hammer and tap the front section to remove...or maybe tap the front section so that
it spins/moves a bit?
Any tips/advice for trying to separate the case sections on a V5 Compressor...
daman on Sun June 13, 2010 4:52 PM User is offlineView users profile
I asked a year ago,since then i got a v5/HT6 holding tool you clamp in the vise then the pump to it,works slick,gota be careful not to distort the case,there tough but will come out.
here
Edited: Sun June 13, 2010 at 4:57 PM by daman
GM Tech on Sun June 13, 2010 6:15 PM User is offline
Use a twisting motion with a vice grip chain grip wrapped around the cylinder- it will come apart. Don't pound on shaft - you'll break the front thrust washer- is is hardened and will shatter easily-- been there done that....
