Side can tap question.
70monte on Sat June 12, 2010 11:51 AM User is offline
Year: 1998
Make: Chevrolet
Model: K3500
Engine Size: 7.4L
Ambient Temp: 80
I've got a quick side can tap question. Does it matter where on the can you put the can tap. Like near the bottom, middle, or top? Thanks.
Wayne
TRB on Sat June 12, 2010 2:16 PM User is offlineView users profile
Close to the top most of the time. We use 30 pound cylinders so don't really use those much anymore.
70monte on Sat June 12, 2010 2:47 PM User is offline
Thanks, I've always put them around the middle or closer to the bottom but I didn't know if it made a difference. I was mainly just curious.
Wayne
daman on Sat June 12, 2010 3:02 PM User is offlineView users profile
Try to upgrade to a top tap Monte much safer operation.
70monte on Sat June 12, 2010 4:50 PM User is offline
How is a top tap safer? Thanks.
Wayne
daman on Sat June 12, 2010 9:30 PM User is offlineView users profile
Just all around better,sealing, piercing,leak potenal,etc,etc...
Dougflas on Sun June 13, 2010 12:18 AM User is offline
at the top as you'll be introducing vapor and the can won't give in stength wise
NickD on Sun June 13, 2010 6:38 AM User is offline
I don't understand the concept of a side tap, seems that is the weakest point of the can. No can tap works if you only need half a can, no matter how hard you tighten it, but not too hard, will smash that rubber washer, it will leak out. That is why I buy cylinders, much cheaper per pound, will always use it, and comes with a built in valve at no extra charge.
70monte on Wed June 16, 2010 6:14 AM User is offline
Thanks guys.
