compressor seal
uawelder on Thu June 10, 2010 12:08 PM User is offlineView users profile
Year: 1983
Make: ISUZU
Model: PUP
Engine Size: 2.2
Where can I buy a shaft seal for a Diesel Kiki model AC compressor. Seriel 3322282 part 350963-8100. This is on a 1983 Isuzu diesel pichup. Thanks Ron
ronald r bird
TRB on Thu June 10, 2010 5:11 PM User is offlineView users profile
If you can locate you model in this PDF I sure i can get a seal kit for it.
Diesel Kiki
uawelder on Fri June 11, 2010 8:55 AM User is offlineView users profile
None of those compressors are like mine. It is on a 1983 model I guess they don't make parts for them anymore. What compressor would replace it? Thanks
ronald r bird
TRB on Fri June 11, 2010 11:03 AM User is offlineView users profile
Check you mounting dimensions and compare to this chart. If they match you can use the Seltec or Sanden but hoses will also be needed as they have a different fitting setup.
