elect problem pontiac montana
jack31ca on Tue June 08, 2010 9:39 PM User is offline
Year: 2000
Make: pontiac
Model: montana
Engine Size: 3.4
Refrigerant Type: 134-a
Ambient Temp: --------
Country of Origin: Canada
im here again when is wired direct it cools but cant get it to work from the switch on the dash did computer reset (disconnect ground wire) as you suggested ,checked for broken wires ,bad connections, what else could it be ? thank you
jack31ca
GM Tech on Wed June 09, 2010 8:45 AM User is offline
Measure voltage at high side pressure transduccer- you should have +5v, Ground, and reference voltage based on system pressure (0 to 5v). I have seen two cars have this problem in last month. Had to re-pin the connector.
