Farm Equipment Charge
mjohnson2981 on Tue June 08, 2010 5:13 PM User is offline
Model: 6620
Ambient Temp: 80
Pressure Low: 16
Pressure High: 187
Completely retrofitted. EVERYTHING new (hoses too) except Evaporator & Condensor
It is a TXV system, fixed cooling fan. (Doesn't depend on ram air, like a car)
Factory charge is listed at 70 oz or 16 oz after bubbles disappear.
I can not get vent discharge air below 58 degrees
From about 48 oz to 64 oz, the guage readings were around 15 and 180, superheat stayed about the same, subcooling gradually increased.
At around 64 oz charge, the guage readings are about the same, but the suction line at the compressor was about 34 degrees (18 deg. superheat) 20 subcooled
At around 72 oz charge, the guage readings are about the same, but the suction line temp jumped to about about 46 degrees (30 deg. superheat) 23 subcooled
Overcharge, I know, but at 80 oz charge, the guages read about 18 and 200, suction line temp is about 48 degrees (29 deg. superheat) 30 subcooled
Am I overlooking something? The low side seams low, but I can't get it to come up. Superheat was in line, but why won't discharge temp drop below 58 if compressor suction is 34?
Any info would be appreciated.
TRB on Tue June 08, 2010 6:34 PM User is offlineView users profile
Is the capillary tube attached to the suction line and wrapped with the tar type tape?
mjohnson2981 on Tue June 08, 2010 7:54 PM User is offline
We retrofitted this last year, and the "professional" ac shop that made the hoses and checked everything out said that the equalizing port wasn't needed and they brazed the hole shut. This year, we have brazed a new fitting on and put on a new externally equalized txv (from deere). Yes, the TXV, bulb, and equalization line are all sealed in cork tape.
bohica2xo on Wed June 09, 2010 2:34 AM User is offline
I am guessing that the numbers are at idle.
Open the cab door. Run the engine speed up to 1500 rpm, and run the cabin fan on high speed - with the 70 ounces installed. Record the pressures while still at 1500 rpm after 5 minutes.
Post the results.
B.
mjohnson2981 on Wed June 09, 2010 7:19 AM User is offline
The numbers are at 1500 RPM with the cab door closed, high fan speed. I will evacuate and recharge today.
bohica2xo on Wed June 09, 2010 12:29 PM User is offline
Ok, if those pressures were @ 1500 - the TXV may need adjustment or may just be defective.
You asked why the delta T was so poor with the low discharge pressures - the answer is refrigerant mass flow. Not much refrigerant passing the TXV for some reason.
Since you are recovering, pull the TXV & have a look through it. Unfortunately, adjusting the superheat means recovering the system for each adjustment on most automotive type valves.
B.
mjohnson2981 on Thu June 10, 2010 10:48 AM User is offline
Something I have noticed, but cannot understand.
There are two cabin air filters on the machine. If I remove one (it is new and not clogged), of course the air flow will increase over the evaporator. Logically, you would think that the suction line temp at the compressor would raise from more heat load. But...
With the cab filter IN suction temperature is about 53 degrees
With the cab filter OUT suction temperature is about 45 degrees... I did this several times and it doesn't make sense to me.
Can someone explain?
ice-n-tropics on Thu June 10, 2010 3:48 PM User is offline
Johnson
Sub cool at 80 ambient temp of 12 to 18 deg. is OK
Retrofit quantity of R-134a is often 10% to 18% of R-12 factory charge for good cooling at 100 ambient
Deere typically uses 50% outside air (OSA) to pressurize the cab to reduce dust intrusion.
Maybe one filter is for outside air and one is for recirculated air.
If the removed filter reduces air flow restriction for recirculated cooler/drier air then OSA is reduced to 25% (recirculated becomes 75%) and louver temp is lowered because delta T of air remains same as 50/50.
hotrodac
