more info on pontiac montana
jack31ca on Fri June 04, 2010 9:01 PM User is offline
Year: 2000
Make: pontiac
Model: montana
Engine Size: 3.4 l
Ambient Temp: 80
Country of Origin: Canada
i have wired the compressor direct and it works , cools ect, i checked the fuses and relays and replaced the presure switch by the dryer it willnot workwhen the a/c button the dash is pressed its not getting elect to the compressor any idea what the problem could be thankyou
jack31ca
GM Tech on Fri June 04, 2010 9:13 PM User is offline
Does the a/c relay have a ground on the negative side of the coil provided by the ecm? If so the ecm is commanding the a/c on and the problem is downstream-- if not the ecm says no to a/c command= and problem is an input to ecm-- as in pressure transducer reading too low.
Also reset the battery to reset any a/c codes....
