Leak under pressure but not under vacuum?
daman on Fri June 04, 2010 1:11 PM User is offlineView users profile
Guy's is this possible? having issues with my HT6 comp on my '99,it will hold great vac over night, I've been over the whole system twice with my tekmate and dye the only place i see dye is the comp(belly leaker) BUT my sniffer picks up nothing in that area not a peep but i do have dye present so i'm thinking that's my problem, but why no hits with the sniffer,coould it be that small?
soooo can they leak under pressure but not vac?
GM Tech on Fri June 04, 2010 2:27 PM User is offline
Absolutely-- leaks can be like farts-- build up and leak every hour or so----that is the benefit of the dye- you don't care when it leaks just where and if it leaks----A sniffer is only good if it is leaking while you are sniffing......
Shaft seals will leak under vacuum and not pressure as well......
daman on Fri June 04, 2010 3:36 PM User is offlineView users profile
Thanks again Tech looks like the comp is suspect then? time for reseal or R&R a different one.
i love dyes for sure.
mk378 on Fri June 04, 2010 3:57 PM User is offline
You could pull compressor, crack it open and try to reseal. The o-ring moves under pressure vs vacuum that's why it only leaks sometimes.
Test your sniffer by unscrewing one of the service port caps, there's always a little refrigerant under them. It should light it up real strong.
daman on Fri June 04, 2010 4:09 PM User is offlineView users profile
Yea i did that ,lights up like a Christmas tree.
it's gota be leaking under pressure because like i said it holds vac over night.
Edited: Fri June 04, 2010 at 4:10 PM by daman
