Chev. G20 Manifold Hose
sdr on Sat May 22, 2010 4:12 PM User is offline
Year: 1989
Make: Chevrolet
Model: G20 Beauville
Engine Size: 5.7L
Refrigerant Type: R12
Without Rear A/C
I replaced the leaking shaft seal on the original (1989) R4 compressor. The good news is that the shaft seal is no longer the major leak, the compressor body o-rings are. Plan B - I bought a new AC Delco compressor and it is partially installed. There are two problems both associated with the manifold hose. The AC Delco compressor is different from the original (1989) R4. The original has 5/8" suction and discharge openings. The new compressor has 5/8" discharge and a 3/4" suction. Also the manifold mating surfaces in the new compressor are not in the same plane. The seal kit with the new compressor includes two aluminum inserts. According to the directions, I should use the short insert in the discharge line since the hose block configuration is the "flat face hose block with short pilots". The first question is, should the insert be a snug fit in the hose block? The directions state, "tap aluminum inserts into block until seated". That sounds like a snug fit, but in mine it is a loose fit. I also have a compressor seal kit from ackits.com with two inserts in it and both are a loose fit as well. Any ideas?
Also, I was going to replace the receiver/drier. It seemed like a good idea at the time. But the tube nut was seized on the receiver outlet. I used some PBlaster and other home remedies but it didn't help. I was successful at removing the nut, but it has some aluminum stuck in the threads. I see that ackits.com shows a replacement manifold hose but I haven't checked on the availability yet. It will be a struggle to remove the aluminum with picks and scribes. Are there any other options to remove the aluminum from the nut?
Thanks.
TRB on Sat May 22, 2010 8:50 PM User is offlineView users profile
Inserts and sealing washer should do the trick. Might need different ones then those that come with the compressor.
GM Tech on Sat May 22, 2010 10:51 PM User is offline
I've never used the inserts--they are for centering the pipe in the manifold if the pipe does not have its own "slip into the compressor pilots"-- here's a big hint-- the red sealing washer goes over the discharge pilot, then I generally just use a basic sealing washer for the suction side..
sdr on Sat May 22, 2010 10:56 PM User is offline
Thanks for your response. Do you think I need a different kit than CP3016, GM Sealing Washers 04 & Prior? I have that in addition to the sealing washers and inserts that came with the new compressor. None of the inserts are a press fit into the manifold block. The sealing washers that came with the compressor seem like they would work fine.
Do you have any suggestions for the problem with the tube nut that connects to the receiver outlet?
Thanks.
TRB on Sat May 22, 2010 11:16 PM User is offlineView users profile
That kit should have the combo you need.
sdr on Sat May 22, 2010 11:32 PM User is offline
GMTech: Thanks. Excellent suggestion. The thickness difference between the red washer and a basic sealing washer is about the same as between the green and yellow washers that the directions call for. The red washer would reduce the gap between the manifold block and the compressor head by about 0.060". But if you use it, that's good enough for me. Now do you have any suggestions on the tube nut that connects to the receiver outlet?
