98 Dodge Ram Clutch Gap Questions
jgcox6 on Mon May 17, 2010 9:11 AM User is offline
Year: 1998
Make: Dodge
Model: RAM
Engine Size: 5.2L
Refrigerant Type: 134
Hey folks,,,My 98 dodge ram has the classic symptoms of the clutch gap has gotten too big. ( A-C shuts off when the truck gets to operating temp and can tap clutch plate and works fine for awhile). Anyway...got a couple of questions...I am thinking in order to fix it, I will need to pull the clutch plate by removing the nut on the front of the plate..then behind the plate are a couple shims....should I just remove one of the shims? Are they all the same size? I think the gap is suppose to be .016-.031 inch??? Should the feeler gauge be hard to pull out or just snug?
GM Tech on Mon May 17, 2010 11:09 AM User is offline
Pull out enough shims to make it so it does not rub when not engaged-- pretty simple logic---shims vary in thickness- you may need to experiment- but I usually hit it on the first try- any thing that creates closer air gap will solve your problem. .020" is a good goal- feeler gage should barely rub both sides when inserted-- that's why it is called a feeler gage...
jgcox6 on Mon May 17, 2010 4:58 PM User is offline
Thank you so much for your reply..I really appreciate it.
jgcox6 on Mon May 24, 2010 4:14 PM User is offline
Just wanted to give the fix to my problem....i did take the AC Clutch off and remove a shim..actually was the only one on the shaft and it brought it within the specs of the ai gap....020...is where it was when I buckled it all up. I just wanted to thank you guys and girls again for you contributing your time and expertise...GREAT JOB!!
