2007 eclipse
Speeddemon145 on Tue May 11, 2010 12:07 AM User is offline
Year: 2007
Make: Mitsubishi
Model: eclipse
Engine Size: 2.4
Ambient Temp: 80
Pressure Low: 30
Hi just replaced my condenser on my eclipse vac it down for a hour as its real humid here in florida and did not want any mosture in there. air is getting down to 33 before cycling. just need to now what the presures for this car should be. I put 2 cans 134a and Part of a 3rd can so far .just do not want to overcharge it and damage something else. Thanks for any help .
TRB on Tue May 11, 2010 12:31 AM User is offlineView users profile
Compressor high pressure kPa (psi) 1350 (196) - 1850 (268)
Compressor low pressure kPa (psi) 40 (5.8) - 110 (16.0)
Speeddemon145 on Tue May 11, 2010 9:17 AM User is offline
Thanks, so I did overcharge it. low side is over 30 psi now but seams to be working fine other than that.
Should i remove some of the freon or will it be ok like it is?
HECAT on Tue May 11, 2010 9:24 AM User is offline
Pressures (high and low) are an indication of system performance not refrigerant quantity.
Speeddemon145 on Tue May 11, 2010 9:32 AM User is offline
Ok will leave it as is then as it is working fine . thanks for the help.
TRB on Tue May 11, 2010 10:51 AM User is offlineView users profile
Agreed, this vehicle should be charged to the OEM specifications. Then use pressures readings to determine system performance.
