Use of ICE 32 in an R-12 system?
monteperformance on Fri May 07, 2010 4:42 PM User is offline
Year: 1987
Make: Buick
Model: Regal
Engine Size: 3.8
Refrigerant Type: R-12
My system needs to be recharged and I have R-12, a new accumulator, and orfice tube that I intend to install. I am going to replace whatever oil that comes out of the old accumulator. I understand that I can use Ester oil, but the only Ester oil I can find in the local stores has ICE-32 additive in it. This is the actual product I bought: "SPAM" Can I use this in my R-12 system? If not what should I use for oil.
Thanks.
Edited: Fri May 07, 2010 at 5:03 PM by Automotive Air Conditioning Information Moderator
HECAT on Sat May 08, 2010 6:14 AM User is offline
use mineral oil
monteperformance on Sat May 08, 2010 12:48 PM User is offline
Is there a certain type of mineral oil I should use? Any idea where to buy it? Thanks.
TRB on Sat May 08, 2010 1:41 PM User is offlineView users profile
41-50000 Mineral Oil for auto a/c compressors.
Edited: Mon May 10, 2010 at 9:40 AM by TRB
monteperformance on Mon May 10, 2010 9:28 AM User is offline
Link didn't work?
TRB on Mon May 10, 2010 9:40 AM User is offlineView users profile
Fixed the link.
chris142 on Tue May 11, 2010 10:05 PM User is offline
What exactly is that ICE32 stuff and how is it supposed to do it?
HECAT on Wed May 12, 2010 10:15 AM User is offline
The million dollar question.
Its based on "Thermolube" from the Shrieve Chemical Group. The composition is of course a well guarded proprietary blend.
I understand lubricant enhancers and additive packages are already in the OE spec refrigerant oils. The OE spec comes from the compressor manufacturers spec; and if more was better, would it not already be in there?
I do suspect the claims that such an additive can rejuvenate worn metal surfaces and lower vent temps, to be somewhat marketing hyped. I don't think that it will do any considerable harm, but I also believe that it will not produce any benefit either.
TRB on Wed May 12, 2010 10:52 AM User is offlineView users profile
Originally posted by: HECAT
That pretty much sums up my opinion on ICE32.
